turn signals and brake lights
I own a 86 cabrio. are ther two different flashers for signals and one for hazrds? My hazards work but no signal lights. any help would be greatly app. I changed fuses and still no luck
RE: turn signals and brake lights
there's another flasher either on the fuse panel or under the dash.
i looked for 2 hours last night, any idea where under the dash? its not on the fuse block
only one relay
try pushing the hazzard switch halfway on the hazzard switch powers the turn signal switch they go bad often |
thank you that seemed to do the trick!!!!!!!!!!
no problem
| All times are GMT -5. The time now is 06:27 AM. |
