Speedometer occasionally wont work
Old Nov 19, 2007 | 02:11 PM
sgtsbud's Avatar
Default Speedometer occasionally wont work
I have a 97 cabrio with almost 100K miles on it. Sometimes when you start the car the Tachometer and Speedometer wont work. Shut it off, let it sit for a few minutes and it will start back. Has anyone had this happen before? Is there a fix for it?
Thanks
Old Dec 1, 2007 | 07:12 PM
Smokin Dog's Avatar
Default RE: Speedometer occasionally wont work
Can't say this is a fix for your VW, however I had one that
did almost like yours, what I did was remove the speedo and
tach cluster, they work on electrical wiring, then I cleaned
all the connections and then found a ground wire that had
worked loose and was just barely making contact, repaired
the ground at the dash and it worked after that.
GOOD LUCK
Jonathan Jones
Jan 30, 2013 08:11 AM
Market11
May 6, 2011 10:02 AM
silentbob06
Jan 6, 2009 08:10 PM
Dewald
Dec 15, 2008 11:33 PM
poston
Nov 4, 2006 07:08 PM
