right side tail lights dont work
Old 07-18-2015 | 04:05 PM
gtarocks's Avatar
Default right side tail lights dont work
I need to know where to get access to wiring diagrams, free if possible. I have tail lights on the left side and not the right side. I have checked and determined that I dont have power. I made the temporary connection from left to right and they lit up. The power is missing from the right side only. So, I dont know where the power originates. Is it only from the left side first? thanks
Old 07-18-2015 | 07:39 PM
You can Google this or buy a workshop manual or ElsaWin of fleabay.
Old 07-18-2015 | 11:04 PM
gtarocks's Avatar
Default found fuse
wow I didnt even realize that the fuse was bad. I thought i had viewed them all. But, also I did not know that there were separate fused for the left and right side.
Old 07-19-2015 | 05:05 AM
Yes there are seperate fuses for left and right. Did replacing the fuse correct your problem and do you have a fuse layout diagram?
Old 07-19-2015 | 04:57 PM
gtarocks's Avatar
Default fuse diagram on google
https://images.search.yahoo.com/sear...g&action=click
That was the image i used for the fuse layout.
The tail light is fixed now. I will keep you all in mind for future use and to help others as i may be able to assist. I have experience and training in electronics and electrical low voltage.
Old 07-19-2015 | 08:41 PM
What year is your Cabrio? I have a 4954 page PDF manual which covers 1995-2002 Cabrio and other models 1995-2005.
  #7
Old 07-20-2015 | 12:09 AM
gtarocks's Avatar
Default PDF manual
I would appreciate access to the pdf file. I have 148,000 miles on it now and will probably need it in the future. The trans and clutch were just changed. I should be getting good life from the car from here on out. Thanks for the support.
  #8
Old 07-20-2015 | 03:56 PM
I've sent you a PM.
LOL.at.VTECH
09-08-2010 09:41 PM
fghjkl
09-11-2009 12:06 PM
LmfGreenBug
11-30-2008 11:26 AM
Kenya_21
05-27-2008 09:32 AM
duckrogers
01-25-2007 01:55 AM
