Power Window Fuse - Unable to Locate?
Hello Everyone
I have a 1999 Cabrio with power windows that suddenly stopped working. They worked when the car was last shut-off, but did not work when started the next time. Checked all options for what was or was not working and the only other thing that is not working are the power mirrors. My first check was of course, the fuse. Should be easy right? Well, it isn't. The fuse for the power windows is not in the bank of 22 fuses, but rather "located above the relays". I'm not sure "how" we're supposed to see above the relays, but in order to do so, I removed the knee bolster (if that is the proper term?) and even though there is a metal support in the way, the fuses can be seen through gaps in the support. According to the manual, the fuse is 20 amp and is Yellow. The problem is . . . I can not see a Yellow fuse. The fuses seem to be randomly spaced throughout the area above the relays and some are fairly hidden. After extensive looking, and moving some wire looms etc. out of the way, I still can not find a yellow fuse. So my question is . . . . How do I locate the fuse for the Power Windows? Thanks so much for reading and helping. Brian |
| All times are GMT -5. The time now is 10:59 PM. |
