-   -   Oil leak (https://volkswagenforum.com/forum/volkswagen-cabrio-34/oil-leak-37285/)
wheelsport Jan 14, 2017 07:35 PM
Oil leak
While poking around under the hood of the Cabrio, I noticed some oil laying in the rings on top of the apparatus above the transmission that appears to be connect to the cooling system. I cleaned it up and went for a fifty mile drive. When I got home, I noticed a burning smell and looked under the hood. The oil is back on top of that same apparatus. I'm not sure but I assume it is an oil cooler.
wheelsport Jan 20, 2017 09:44 AM
While poking around under the hood of the Cabrio, I noticed some oil laying in the rings on top of the apparatus above the transmission that appears to be connect to the cooling system. I cleaned it up and went for a fifty mile drive. When I got home, I noticed a burning smell and looked under the hood. The oil is back on top of that same apparatus. I'm not sure but I assume it is an oil cooler. Where is the oil coming from and how can I fix it?
wheelsport Feb 23, 2017 08:52 PM
I found out that the leak was coming from a bad 'O' ring on top of the tranny oil cooler. The fix was quick by replacing the 'O' ring under the allen nut on top of the cooler.
