shepnuts |
11-24-2010 08:10 PM |
not starting ;(
my friends 2000 cabrio doesnt make a sound when you turn the key. It has had intermittent starting for the last two months, then finally quit for good. i changed the ignition switch, which was cracked, and it didnt fix the problem. i tried jumping the solenoid, no luck. test light showed power to the solenoid, but i havent checked the wire to the starter from the solenoid yet because i couldnt immediately see it from above, and i didnt want to get under it because its raining right now ;). checked every fuse. anyone ever have this happen?
