VW Cabrio no power to fuse and a/c
Old 05-09-2018, 09:36 AM
Noelstone's Avatar
Default VW Cabrio no power to fuse and a/c
All at once, per my daughter, our 2002 Cabrio convertible appears to have lost power to the A/C along with the Gas Gauge and speedometer stopped working. I've checked fuses and fuse 11&12 don't have any power to them so trying to track down where this fuse gets it's power although. I don't believe this is connected unless it's coming off a relay that happens to control these items. A/C doesn't even start not does the on/off switch light up. At the same time the brake light is staying on but emergency brake is on. I'm interested in any I and where I might find a list showing where each fuse is getting power as good start would be if anyone knows where power to fuse 11 and 12 comes from.
Old 05-10-2018, 07:44 AM
discarn8
10-23-2012 04:04 AM
vwvwv
09-12-2011 06:32 PM
irishlassie71
09-10-2011 09:38 PM
02-27-2011 12:52 AM
pwell61
01-12-2007 09:10 PM
Quick Reply: VW Cabrio no power to fuse and a/c
