-   -   Golf Cabrio 2.0 2001 Gearbox code (https://volkswagenforum.com/forum/volkswagen-cabrio-34/golf-cabrio-2-0-2001-gearbox-code-37358/)
Roy58 May 4, 2017 07:02 AM
Hello First time user on this forum and it has already been very useful.
I have been trying to source a gearbox for about a month now. I have asked our local vw dealer if it only the 3 letter code, mine is DFQ, that is required. They said there should be a 9 number code as well. The code on my box is DFQ 03051 with 14 under the DFQ and 5 under the number. I have recently found a second hand gearbox but it only quotes DFQ in the advert do I need them to confirm the number as well or is it likely to be compatibles.
Keithuk May 4, 2017 09:16 AM
Manufacturer: VW, Date(s) Used: 08/1995-06/2002, Model: Golf, Transmission Code: DFQ, Transmission Type: 5S
There are other VAG models that use the same.
Manufacturer: Seat, Date(s) Used: 07/1996-06/1999, Model: Ibiza Stylance, Transmission Code: DFQ, Transmission Type: 5S
Manufacturer: Seat, Date(s) Used: 07/1996-06/1999, Model: Cordoba/Vario, Transmission Code: DFQ, Transmission Type: 5S
Manufacturer: VW, Date(s) Used: 08/1999-09/2001, Model: Polo, Transmission Code: DFQ, Transmission Type: 5S
Manufacturer: VW, Date(s) Used: 08/1995-12/1998, Model: Jetta, Transmission Code: DFQ, Transmission Type: 5S
Manufacturer: VW, Date(s) Used: 08/1995-02/1999, Model: Vento, Transmission Code: DFQ, Transmission Type: 5S
Roy58 May 5, 2017 06:09 AM
Thanks for the info Keith. I think i have sourced one from the same model as mine. If it doesnt work out I will be looking the other you've mentioned.
Thanks again Roy
