Fuel pump sending unit - 1995 Cabrio
Old Dec 18, 2013 | 07:47 AM
ChrisBrooks's Avatar
Default Fuel pump sending unit - 1995 Cabrio
Help! I had to replace the fuel gauge sending using because it was not registering fuel level. The pump is fine. I'm OK with the two lines on top of the pump assemble, but now, I'm not getting fuel.
There are two plastic lines from the sending unit connected to the pump. Would it be that I have them reversed? I'm getting a small leake on top of the assemply now also and was thinking this may be the case. There are no arrows to indicate the direction to place the plastic lines to the pump.
Thank you all
Old Dec 19, 2013 | 07:43 AM
Welcome to the forum Chris. Name:  VWwelcome.gif
So the car ran ok before you changed the tank sender apart from the fuel gauge not working?
We don't know full details of your motor.
You could have reversed the pipes you should have marked from before removal. Some sender units have arrows showing the flow, some have larger fuel feed pipe than the return. When you turn the ignition on the pump should run for a couple of seconds to prime the system. Reverse the pipes and see if it runs.
Old Dec 21, 2013 | 12:44 AM
MarianoKnisley's Avatar
hey buddy .. greetings from the board and i hope we will be all good by together and supporting each other
ItsNachos
Jan 17, 2012 07:33 AM
JDUB
Jun 8, 2006 06:19 PM
mbz300sdl
Feb 27, 2006 08:56 PM
hotrodrocco
Nov 20, 2005 12:01 PM
Jettaguy
Jun 25, 2005 04:14 PM
