Can the immobilizer lock the ignition switch?
Old Jul 15, 2018 | 01:38 AM
surf2kona's Avatar
Default Can the immobilizer lock the ignition switch?
I just bought a 2000 Cabrio convertible. I think it still has the alarm and immobilizer that came with the car. Last week the driver side door lock stopped working, so I had to crawl in through the trunk. The car started, but the alarm went off every time I started the car. Fortunately, I have an extra key so I just open the trunk which makes the alarm go off (the trunk lock is still working). Initially the alarm went off every time the car was started.
A few days ago, I was driving with a friend. When he got out the passenger side, the alarm went off. Since then the alarms goes off every time the passenger side is opened and about 80% of the time when the car is started. The cylinder for the driver side door does not arrive until later this week, but I was OK with using the trunk workaround until then.
This morning though, I got in the car and the ignition cylinder will not turn. It budges a fraction of an inch, but not much. Three questions:
1) Is it possible for the immobilizer to cause the ignition switch to lock up?
2) Are there any ways to fix this issue (other than replacing the ignition cylinder?
3) Is there a phone number at VW where they can answer questions like this?
Thanks,
Brian
Old Jul 15, 2018 | 07:50 AM
The alarm siren is another issue.
The immobilizer won't case the ignition switch to lock up, it will start for a second or two then stop and the immobilizer light will be on in the dash.
Faulty ignition switch is a common problem which you can Google.
Jan 7, 2011 06:03 AM
andyk97golf
Oct 23, 2008 07:44 PM
eva
Feb 9, 2007 02:08 AM
kungfuftr
Oct 22, 2006 05:08 AM
Pootle
Jan 8, 2006 12:02 PM
