'96 Cabrio Weird Problem
Old 04-21-2008 | 11:47 AM
disney8113's Avatar
Default '96 Cabrio Weird Problem
Over the weekend I changed my fuel filter, a day later when I went to get in my car and go the door ajar chime was stuck on and the ciggarette lighter wouldn't work. After spending a few minutes trying to figure out if there were wires loose and what not I removed the ciggarette lighter and the door chime went off. To me this sounds like whoever owned the car previously somehow re-wired the door chime to the lighter. I have had this car for three weks and used the lighter multiple times and used it as an outlet for my cell charger now it won't work for anything but to make the door chime stay on. Any suggestions? Also, my power locks just went out in it and I need a new map light, If anybody could direct me to these two things I would appreciate it. Thanks a bunch!
Old 04-21-2008 | 07:07 PM
bagel's Avatar
Default RE: '96 Cabrio Weird Problem
Did you check fuses?
Old 04-21-2008 | 10:50 PM
Jrailer's Avatar
fuses
Old 05-21-2008 | 09:09 AM
disney8113's Avatar
ok, so my power windows have now gone out. When I was checking the fuses for the windows I fixed the original problem of the door chime and everything but now I still can't get the windows to go up. The doors will only lock from the inside as well. Does anybody have a suggestion for this new problem?
vwjetta11
12-09-2013 08:41 PM
aaron77
04-17-2011 03:38 AM
cocheeze
08-22-2009 07:00 AM
theskinnyguy1
04-29-2009 12:56 PM
Robaire
01-28-2008 07:56 PM
