96 Cabrio Fuel Pump Issue
My wife drove her 96 Cabrio a few days ago. When she got ready to drive home, it wouldn't start. I called a tow and had it returned to my garage. It is a 2.0L ABA OBDII with auto transmission. No "Check Engine" light. The light works when starting the engine. It would crank, but not start.
Which wiring diagram are you using?
You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing. You can investigate more components with VAG-COM\VCDS. If you have a 109 relay you can crank it all day and it will never start, its the main power feed to the ecu. https://volkswagenforum.com/forum/ne...gnature-34185/ |
I am using the Bentley manual for testing and wiring diagrams. I don't have or have access to VAG-COM. But, I do have a OBDII scan tool that can reset codes. It shows no codes stored at this time. I do not have relay 109.
In my original post, I mentioned in item #9, the Bentley test said I should have an intermittent ground signal from the ECU to pin 85 on the fuel pump relay. When I turned the key "on", the signal was steady for at least 30 seconds. Last evening, I had my wife sit in the seat while I hooked up a jumper wire from the battery (B+) to the fuel pump. The pump ran and I could hear fuel sloshing through the pump hoses. Probably air that was introduced when I pulled the fuel supply line from the fuel rail during initial testing. I had her try to start the car. On the first attempt, it sounded like a cylinder or two fired. The next two attempts.....nothing. Multiple problems, or am I overlooking something? |
