81 cabriolet won't start.
Old 05-22-2018, 12:36 PM
Ardvent's Avatar
Default 81 cabriolet won't start.
heylo:
My 81 cabriolet, 1.7 litre, CIS won't start. I bought several years ago as a non runner. I got it running good, and then last summer it just died while driving. I replaced the fuel pump and relay, and still no wrrrrr sound from the pump, won't start. Research from the Internet told me to run a jumper wire from the control pressure regulator positive to positive on battery. Well, it Started right up. So , where do I go from here?
Any advise would be appreciated.
Larry
Old 05-23-2018, 04:50 AM
Have long is a piece of string? That's why you Goggled and joined this forum.
Its could be loads of things. You need a wiring diagram for your motor to check all wiring & connectors. 81 models can't use VAG-COM\VCDS without the 2x adaptor .
mail4ajc
04-15-2022 06:09 PM
sohan_88cab
05-16-2013 12:27 PM
wearyourtruth
01-02-2009 01:29 PM
ineedabin2
08-26-2008 07:56 AM
climberman
12-15-2005 05:07 PM
Quick Reply: 81 cabriolet won't start.
