2001 Cabrio GLX - 4 way Flasher Clicks
I have replaced the 4 way flasher switch on dashboard, replaced the 4 way Relay by steering column and even replaced the turn signal switch on the column. As soon as I turn on the key ,and when vehicle is running.. the relay starts clicking I can feel the relay and hear it. The 4 way flashers work when depress button on dash. red light blinks on dash same tempo as relay clicking .. Turn signals work as normal, all the bulbs are good. Marker lights work. Turn key off, flasher relay stops clicking .
Any one have any ideas . I am at wits end, everything is replaced. New to VW's and to this Forum . Any help would be appreciated thank you in advance..! |
1 Attachment(s)
Welcome to the forum. Attachment 2454
Have you Googled this? VWVortex.com - Turn signal relay clicking (hazard switch replacement) - problem fix and thanks!! https://volkswagenforum.com/forum/ne...gnature-34185/ |
Originally Posted by Keithuk
(Post 63056)
Welcome to the forum. http://i10.photobucket.com/albums/a1.../VWwelcome.gif
Have you Googled this? VWVortex.com - Turn signal relay clicking (hazard switch replacement) - problem fix and thanks!! https://volkswagenforum.com/forum/ne...gnature-34185/ THANK YOU VERY MUCH. ! I can not believe that a can of electronic cleaner sprayed into the turn signal switch would remedy that problem. I sprayed half a can into the switch while moving turn signal switch up and down(turn signal) and forward and back(high and low beam) wiped over spray off where ever it splashed. waited about 5 minutes for the residue to evaporate. Low and Behold - NO MORE CLICKING , unless I use my Blinker or Flasher.. I can not express my thanks sufficiently for your help....! Adam |
