Were is the air conditioner drain line? My dad is going crazy - everything works but no cold air comes out and there isn't ever any water under the car. The air condictioning lines get cold and even freeze uo sometime.
Under the hood just to the passenger side of center, lower down on the firewall. Mine was hidden behind the foil like insulation knock out. There's a round rubber fitting with 2 drain holes. I pulled the rubber fitting off the firewall (it can only go back on one way) there was the end of the line from the condensate pan. I took my long narrow and flexible mechanical fingers device and worked it up the drain hole. I hit something, then the mighty dam broke! Water poured out for about 15 seconds. Turned on the a/c and water stopped draining into the front floor. Put the rubber fitting back on, Done.
2001 Cabrio A/C condensate drain on firewall Condensate flood after clearing line
Reason: Attach photo
