-   -   1998 Cabrio oil leak (https://volkswagenforum.com/forum/volkswagen-cabrio-34/1998-cabrio-oil-leak-38824/)
Pkjeld Feb 13, 2022 10:02 AM
I just bought a 98 Cabrio and noticed it has a nice oil leak on the driver side of the motor. It looks like it may be coming from the top radiator hose where connects to the block. I wouldn’t think that’s the spot butt can’t see any thing.The valve cover gasket appears to be dry all the way around. Thanks
Dpricenator Aug 4, 2022 02:36 AM
I am having the same issue. Imine looks like the circular area under the oil fill cap, on the driver's side of the engine. Is that a know leak point, or is it more likely the valve cover gasket?
Pkjeld Aug 7, 2022 02:05 PM
Oil leak
my oil leak was coming thru the oil pressure switch and the coolant leak was a bad gasket on the housing just below pressure switch.
