1995 Cabrio transmission compatibility
Old Dec 17, 2013 | 07:57 PM
IanJ's Avatar
Default 1995 Cabrio transmission compatibility
I recently bought a '95 Cabrio, only to discover that the four speed auto transmission won't shift into fourth gear (yes, you may mock me for poor purchasing wisdom!).
The shop says that the transmission is indeed shot and my plan is to swap it out for a standard. I understand that this is quite doable, my only question is compatibilty. There is a '93 Golf for sale in my area that would make a good donor - does anyone one if the transmission would be compatible or how I can find out? Thanks! =D
Old Dec 18, 2013 | 07:19 AM
Welcome to the forum Ian. Name:  VWwelcome.gif
Finding compatible transmissions isn't easy as there are so many gearbox codes.
VW Transmission Codes
Old Dec 18, 2013 | 11:57 AM
IanJ's Avatar
Thanks Keith!
My transmission code, then, is CNK (found thanks to a handy post called 'please tell us your car spec in your signature' ).
The link you gave me shows that transmission in:
CNK 4A 09/93-01/95 GOLF
CNK 4A 01/94-12/94 GOLF "CDN"
CNK 4A 01/94-12/94 GOLF "USA"
CNK 4A 08/94-12/94 JETTA
It seems to correspond to manual transmission code CHE:
CHE 5S 08/92-12/93 GOLF
CHE 5S 01/94-10/95 GOLF "CDN"
CHE 5S 01/94-10/95 GOLF "USA"
CHE 5S 08/92-07/93 JETTA
Would you consider it safe to attempt a swap to with a CHE from a '93 Golf?
Old Dec 19, 2013 | 07:56 AM
Originally Posted by IanJ
Thanks Keith!
Thanks Ian for pointing that out, perhaps you can convince MarianoKnisley? https://volkswagenforum.com/forum/ne...e-34185/page2/
As I said they aren't easy to match a compatible gearbox you really need to find people that have done this successfully.
I don't really like promoting other forums but this one is very good as Crasher is very knowledgeable as he has is own Audi/VW workshop. Users have asked which gearbox will fit their model and he's told them.
VolkswagenForum.co.uk - UK's #1 VW Forum
That's another forum I ask users to add their car spec to their signature so you will be used to that. If you join I assume you will use the same username.
checos
Mar 17, 2012 03:52 PM
buddyboy1995
Nov 19, 2010 10:59 PM
GMAN
Aug 10, 2009 03:13 PM
GMAN
Aug 10, 2009 01:50 PM
sheldoggy
Sep 14, 2006 11:22 AM
