WHISTLE UPON STARTING
Old Apr 24, 2008 | 08:14 AM
2003 VW BEATLE TURBO's Avatar
Default WHISTLE UPON STARTING
HIGH PITCH WHISTLE , HAPPENS MORE WHEN IT IS COLD. CAR RUNS FINE TURBO IS QUIET
Old Apr 24, 2008 | 08:44 AM
mausolfh's Avatar
Default RE: WHISTLE UPON STARTING
Check the air cleaner assembly. It could be as simple as a leaf caught up in the intake, it has happened before. Also check rubber hoses to the intake manifold for cracks or loose clamps.
Old Apr 24, 2008 | 07:44 PM
Jrailer's Avatar
secondary air pump
might have a hose off
Old May 4, 2008 | 08:30 PM
woody1's Avatar
Member
What is it with the hose's on thouse things. mine came off on both ends, and was a pain in the behind to put back on.[>:]
Old May 12, 2008 | 05:50 PM
sagebsf's Avatar
I have a 2001 Beetle...not a turbo, but when I start it my car it will sometimes sound like the belts are being ripped at.... (Kinda like when you use a scissor to make ribbon on a present curl up...but much much louder.) Maybe you call that sound a "whistle?" I brought the car to the dealership and they said it's nothing to worry about. It only happens every once in a while though, I'm not too concerned. Hasn't been a problem aside from the embarassment I get when people look at me funny.
Old May 13, 2008 | 02:55 PM
crystal_red's Avatar
Fan Belt?
Old May 13, 2008 | 06:15 PM
  #7
bagel's Avatar
Mine does it too...bout 1-2 second sound. Prolly starter gear.
Old Oct 29, 2011 | 10:19 AM
  #8
esse1061's Avatar
Could also be your secondary air pump going or about to be bad. Mine does it too I just haven't found a replacement at the junk yard yet. Easy to replace. it's mounted at the front right under the intake manifold, next to the orange oil dipstick.
05GLI
May 18, 2011 02:19 PM
Mar 4, 2011 12:23 AM
iluvjetta
Jul 6, 2010 11:14 AM
sungail
Jan 28, 2009 03:26 PM
sleeper2.0
May 12, 2008 10:29 PM
