warning lights and oil leak
HI TO ALL,I am new this this forum, and also new to owning a 1966 vw beetle. i have searched the internet and can not find out what warning lights are in the bottom of the speedometer. i know the red one on the left is generator, in the middle is turn signal, there is a green one on the right, not sure what it is. i am assuming it is oil pressure, also is there a temp light? and i also have 2 little oil spots in my garage, just sondering how i can tell if it is the orings on the push rod tubes?
thanks for all the info that you can give me Bill |
Hi
Ok you are right about the two lights on the bottom of the speedometer the one is your alternator and the other is your oil pressure there is no temperature light. Hope I could help Have a nice one. |
| All times are GMT -5. The time now is 04:10 AM. |
