-   -   Vanity Mirror Light Bulb Stock part number? (https://volkswagenforum.com/forum/volkswagen-beetle-20/vanity-mirror-light-bulb-stock-part-number-37236/)
scottyboy24 Oct 26, 2016 09:27 PM
Looking to verify that this would be the correct LED replacement?
3710 LED Bulb - 3 SMD LED Festoon - 38mm
This is the Stock #: 6418 I came up with at a site called :
https://www.superbrightleds.com/vehi...=441&year=2010
Just hoping someone may have replaced these before and verify that this bulb will work and maybe give me a heads up on how to remove the old ones?
My daughter has the car so I can't check it out until tomorrow evening, so I have no clue if it is simple or a pain?
Thanks!
Keithuk Oct 27, 2016 06:29 AM
Normally fitting LED bulbs gives a bulb out warning you have to put an extra resistor in. Have you Googled vanity mirror light bulb beetle changing?
scottyboy24 Oct 27, 2016 11:19 PM
Yes, I have always had to use them on led blinker bulbs to keep them from hyper-flashing too.
So I just ask the seller on ebay that has some i am looking at, and he said I would not have to install a load resister on this VW. But we will see. If I do I will probably just forget it and return them, before I screw with this German wiring on this little Beetle.
Oh by the way. Do you know by chance exactly how long the MAP LIGHT bulb is? I think it is either 36mm, 37mm, or 38mm.?
Thanks for the reply!
