turn signal switch
I am restoring a 1966 beetle and just got a new turn signal switch, but there is no wire diagram to help identify the wires. the wires coming out of the switch housing are as follows: (1) Brown
(2) Brown & white striped-with brown wire leading on from the spade connector
(3) Black- with blue wire leading on from the spade connector(spade connector at end of blue is a mini size)
(4) Green and black striped
(5) Black & white stripe
All wires have regular size spade connectors(except as noted in (3)
I am learning as I go along. Can anyone please help me identify the wires so I can connect them correctly? Thank you for any help.
