tranny help
hey guys, my '65 beetle has been having some weird things going on... the left rear(least we think its left) has been making a clicking sound whenever you drive(reverse forward) or just push it in neutral. i was wondering what could cause this, is there any way for me to check? i was thinking of driveshaft or somthing else of that location.
any help will be thought about -chris |
RE: tranny help
i kinda found out through research it is most likely cv joints, are these hard to fix, or expensive?
RE: tranny help
Well unless things have been swapped out your 65 won't have cv joints. There's quite a bit that could cause clicking noises, you're going to have to get down and locate where the noise is coming from. Could be anything from a stripped torsion bar or associated part to gears to a wheel bearing. It could even be a driveshaft haning up.
Get someone to help you push the car forward and backward to make the noise and try and figure out where it's coming from. |
RE: tranny help
how to get info on vw passat tranmission please
