spoty battery faliure
Old Feb 19, 2008 | 06:34 PM
mshelby's Avatar
Default spoty battery faliure
The battery in my 99 GLS keeps draining. There is no rhyme or reason and it's certainly not a constant occurance, which makes it even more anoying. Sometimes it can sit for days and fire right up. Other times it will drain in a few hours.
All fuses are good, and the alternator seems to be charging the battery up. Once started, the car never gives me any trouble. Any thoughts would be appreciated.
Old Feb 20, 2008 | 12:54 PM
bagel's Avatar
Default RE: spoty battery faliure
so basically one day it starts, the next day it doesn't cause the battery is dead?? You could do an alternator check, but most of the time it would be a dead cell in the battery. Have you changed batteries and had the same problem? Maybe is something as simple as not closing the door all the way and interior light is draining the battery.
Old Feb 21, 2008 | 05:24 AM
jonnyoutram's Avatar
yeha check that all the door pins are working and that everything electrical is always shut down, but also, i had the same prob and found an old positive amp wire from someones old sound system under the carped, this was sometimes earthing on the floor pan and draining the batt! unlikley but worth a look!
sknyppy
Feb 9, 2007 12:20 AM
covergirl
Sep 24, 2006 05:09 PM
redoo
Jul 31, 2006 11:39 PM
exojj
Feb 4, 2006 08:21 PM
kirsty willett
Dec 20, 2005 03:13 PM
