-   -   Painting Help (https://volkswagenforum.com/forum/volkswagen-beetle-20/painting-help-6581/)
bandgeek1 Oct 4, 2008 02:39 PM
Painting Help
Ok so I am going to paint my 66 Bug soon, never done it before, but i have done my homework.
One question tho, I want to paint the fenders the same as the car, is there any special kinda of paint i need to use on them?
Thanks
bagel Oct 4, 2008 02:41 PM
RE: Painting Help
What material is the fenders made out of? You shouldn't have a problem, but are you wet sanding between coats?? What type of clear coat sealer do you have??
bandgeek1 Oct 4, 2008 03:42 PM
RE: Painting Help
They are made out of rubber.
And i have not started painting yet, still doing some research. If there any tips tho, i would appreciate it.
Jrailer Oct 4, 2008 04:47 PM
RE: Painting Help
rubber fenders?
bagel Oct 5, 2008 01:15 PM
RE: Painting Help
Fenders aren't made out of rubber, usually a plastic or a composit material. I wet sand in between coats with 500-800 grit sandpaper. paint-wet sand...paint-wet sand..and then paint and you should be fine. You have to clear coat after you're done painting. Don't go to fast cause you'll get blotches, go to slow you get runs. Test on a separate peice of metal to see what you're paint will look like.
Jrailer Oct 5, 2008 02:16 PM
RE: Painting Help
ya a 66 bug should have metal fenders
might have some fiberglass aftermakets but i have never seen rubber ones
