overheating
i have a 2000 beetle and its overheating fast...the cooling fans do not come on at all? and my heater fan dont come on...air cond fan ect.......is there a fuse that could be blown or a switch?relay?that controls both fans ? strange both fans inside and out dont work...checked all fuses in car....help.....
RE: overheating
check the fuses on top of the battery
RE: overheating
i checked all fuses even pulled them out and checked them...i think my water pump is bad because its not circulating back to tank...?would that make the radiator fan not come on because its not circulating??? also my air cond fan or heater fan dont blow is that a comon problem switch maybe? anyone know ????
RE: overheating
help help help????been messing with this thing for two days i ordered water pump so thats on the back burner but the air cond switch and fan blower for heater dont work...is there any fuses other then the side panel and battery area???it acts like the air cond and blower are not getting power
RE: overheating
try moving your key switch back just a little for the blower do your wipers work?
ya pump could do that you should do a t belt and tens. if your going to do the pump |
