Need Help 99 NEW Beetle!!
VCDS-Lite Version: Release 1.1
Wednesday, 12 January 2011, 15:50:10:44011 Control Module Part Number: 06A 906 018 JE Component and/or Version: MOTRONIC M5.9.2 AT V01 Software Coding: 00001 Work Shop Code: WSC 01120 VCID: 6EAFE6503999 3 Faults Found: 01165 - Throttle Body Control Module (J338) 55-00 - Adaptation Not Successful 17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large P1544 - 35-00 - - 16505 - Throttle Position Sensor (G69): Implausible Signal P0121 - 35-00 - - What CAN i do? |
Originally Posted by piyush123
(Post 51563)
3 Faults Found:
01165 - Throttle Body Control Module (J338) 17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large 16505 - Throttle Position Sensor (G69): Implausible Signal Fault Location: Throttle Body Control Module (J338): Adaptation Not Successful Possible Cause: Throttle Body Adaptation Conditions not met. Throttle Body Control Module (J338) faulty. Possible Solutions: Check for other Throttle Body related Fault Codes. Check Throttle Body Control Module (J338). VAG Error Code: 17952 EOBD II Error Code: P1544 Fault Location: Throttle motor position sensor 1 - high input Possible Cause: Malfunction indicator lamp (MIL) Triggered on first occurrence. Wiring short to positive. Throttle motor position sensor. VAG Error Code: 16505 EOBD II Error Code: P0121 Fault Location: Throttle position (TP) sensor/switch A/Accelerator pedal position (APP) sensor/switch A - range/performance problem (G69) Possible Cause: Malfunction indicator lamp (MIL) Triggered on first occurrence. Accelerator cable adjustment. Throttle position (TP) sensor/switch. Accelerator pedal position (APP) sensor/switch. As taken from my Free EOBD II Error Codes software ;) |
| All times are GMT -5. The time now is 08:33 AM. |
