-   -   Master / Slave cylinder issues? (https://volkswagenforum.com/forum/volkswagen-beetle-20/master-slave-cylinder-issues-37416/)
myellow03 Aug 14, 2017 12:58 PM
The clutch pedal on my 04 1.8T has gotten soft, but doesn't lay on the floor, and it is hard to get the car into gear while running. I do not see any obvious leaks.
Any suggestions on what to look for?
Keithuk Aug 15, 2017 08:16 AM
The clutch pedal shouldn't lay on the floor. Try bleeding the clutch hydraulics.
myellow03 Aug 16, 2017 06:46 AM
I was not implying the clutch pedal should lay on the floor, even a monkey knows the clutch pedal should not lay on the floor. I was saying the clutch pedal is soft but not soft enough where is lays on the floor.
There's always one.
Keithuk Aug 17, 2017 06:30 AM
Well that's just bad wording. If the clutch pedal is soft meaning there is no resistances check the clutch hydraulics.
