interference motor??
Old 05-02-2017, 10:22 PM
torinoman's Avatar
Default interference motor??
Anyone out there know if the 2003 2.0 L is an interference motor or not ? Timing belt jumped a few teeth,,
Old 05-03-2017, 08:25 AM
Yes it is.
Check for Engine Damage:
CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve to piston damage in the event of a timing belt failure is MOST LIKELY to occur. A compression check of all cylinders should be performed before removing the cylinder head(s).
gmohamedi
09-30-2010 02:23 AM
daiz
10-11-2009 11:01 AM
tnonk17
06-22-2007 05:37 PM
bpetry
03-23-2007 01:14 AM
emagdnim
08-24-2006 07:17 PM
Quick Reply: interference motor??
