-   -   Ignition Questions? (https://volkswagenforum.com/forum/volkswagen-beetle-20/ignition-questions-6821/)
gagallagher04401 Nov 16, 2008 09:07 PM
Ignition Questions?
Hey all
I have built a VW trike with a 1600cc single portVW engine. everything is great, runs good, this winter I am doing some work making it a little nicer come spring.
I would like to put a electronic ignition on it, to eliminate pints, and condenser, make more reliable and gain what performance, and reliability I can. But I will be honest I am little nervous about doing it, because it does run nice now, but I think it can run better, and be more reliable for a longer time by doig this conversion.
I am not sure what my coil is it is black lol
Should Iinstall just electronic ignition, or whole new distributor setup/coil?
I would like to do this as cheap and easily as possable.
What should I go with? Comments? Idea's? thoughts?
Thanks
George
Jrailer Nov 16, 2008 09:12 PM
RE: Ignition Questions?
protronic is a good one
i like the points better if they go bad you can still open them up and get home if the electronic gose bad you are dead in the street
and you wont see much if any performance increase
