Horn problem?
Old Feb 19, 2007 | 04:30 PM
spitvalve4's Avatar
Default Horn problem?
I need some help? I own a 1971 bug and recently installed a new horn. When I start the car, the horn will stay on. Finally, I had to
unhook one of the connections. Could it be that the connections are
simply crossed? (You can tell I'm not a mechanical guru.)Thanks.
Old Mar 1, 2007 | 11:51 PM
sierrabravo's Avatar
Default RE: Horn problem?
I have the same problem with my 1970 bug, I also had to disconnect the power wire for the horn to keep it from going off all the time. If anyone knows about this problem, let us know. If not, I'm just going to try to fix it myself y/not
Old Mar 17, 2007 | 11:58 AM
finbar06's Avatar
check horn relay and ground wire , if you have power to the horn go to the horn switch itself in the steering wheel and check that it is not touching the sides etc.
vdubbin95
Jun 15, 2007 10:39 AM
vdubbin95
Jun 5, 2007 01:50 AM
petfre326
Oct 15, 2006 04:33 PM
p_mister
Mar 23, 2006 07:37 PM
bowman
Mar 19, 2006 09:51 PM
