Help with a New Turbo Beetle
Old Jun 2, 2006 | 01:35 AM
starnurse's Avatar
Default Help with a New Turbo Beetle
Hi, I have an automatic 2003 Turbo VW Beetle. It will not shift into gear & the brake lights do not work. I can mess with it & keep trying & then it will work (when it will shift the brake lights work). Someone please help!
Thanks in advance,
Starla
Old Jun 13, 2006 | 10:23 PM
Kim's Avatar
Kim
Default RE: Help with a New Turbo Beetle
try the neutral safety switch
Old Jun 13, 2006 | 11:29 PM
Jsd's Avatar
Jsd
Sounds about right, might be faulty wiring or solenoid, we had another member with similar issues.
Old Jul 12, 2006 | 01:33 AM
Springer's Avatar
Your Brake light switch or (Stoplight switch as some call it), is not working properly. It is the little plastic switch mounted on the arm of your brake pedal. VW swapped mine out under a recall or warranty, can't remember.
Ramza
Feb 3, 2014 07:53 AM
jayelwin
Sep 17, 2008 11:15 PM
swampback
Dec 23, 2007 06:33 PM
kev510
Nov 19, 2007 03:23 PM
freebug
Sep 14, 2006 02:31 AM
