-   -   fuel tank door (https://volkswagenforum.com/forum/volkswagen-beetle-20/fuel-tank-door-4826/)
mtnbug Jan 16, 2008 08:57 PM
fuel tank door
I've got a 2001 beetle, more than likely an easy fix but my fuel tank door won't open from the switch, looked for a designated fuse couldn't find one, did get the door to open by pulling the cable, thank you owners manual ! There is no usual noise from the switch , does this share with anouther fuse, if so which one? Any help would appreciate, Thanx!
Smokin Dog Jan 18, 2008 11:47 AM
RE: fuel tank door
All you have to do is look for a blown fuse in the entire
fuse panel, best to use a 12 volt test light to ck them.
