Engine Stutter
Old Jan 14, 2008 | 04:04 PM
irishlad78's Avatar
Default Engine Stutter
I have a 75 fuel injected Super Beetle I've owned for about 5 months now that has mostly been running just fine. However, I went out yesterday to the store this weekend and all was well, but when I started the car up to return home, I noticed a fairly prominent and sometimes violent stutter from the engine when the gas was applied. I've tested out driving it a bit more since and the problem still persists, if not as intense as on the first time I experienced it. What are the possible causes for this? What should I check for? Is there anything that would be easy (and I do mean easy, I'm no gearhead) to fix by myself? Thanks!
Old Jan 14, 2008 | 04:52 PM
vdubinzhouse's Avatar
Default RE: Engine Stutter
theres a few things you could check, like the motor mounts, or it could also be in need of a tune up (plugs,wires,rotor and distributor cap) ? just a couple of ideas to look for , good luck!
Old Jan 24, 2008 | 08:26 PM
Smokin Dog's Avatar
Not to down your 75 beetle, but that area fuelinjected
system didn't work well when it was new, it was a freak
car. A lot of people change them over to a carb engine
to make them run correct. That fuel injection system was
VW's attempt to make them pass the American polution
requriements and it didn't work.
BradlehR
Jan 29, 2013 08:46 AM
WunderKar
Apr 23, 2010 02:57 PM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
dusty420
Aug 31, 2006 01:01 PM
