-   -   engine stalling problem (https://volkswagenforum.com/forum/volkswagen-beetle-20/engine-stalling-problem-6775/)
enginekid92 Nov 8, 2008 09:40 PM
could someone please tell me why my 71' bug engine (in a dune buggy) stalls at idelafter the choke is about 3/4 of the way offunless i constenly rev the engine, i alredy checked the idel cutoff, also it won't let me set the timing where it's suposed to be (7.5 deg. btdc) i can only get it to about 2-3 deg. btdc before it won't run at all, o forgot to metion when the choke starts to go off i loose power very quikly as the choke goes off more and more, and i just rebuilt the carb.
Jrailer Nov 9, 2008 10:28 AM
RE: engine stalling problem
sounds like a pluged idle jet
enginekid92 Nov 9, 2008 11:19 AM
would it help if i posted a video of how it runs and would that explane having so little power that the buggy will only move on a flat suface once the choke goes off
enginekid92 Nov 9, 2008 12:24 PM
well acording my ceiling scale the whole buggy is only 532 lbs.
enginekid92 Nov 9, 2008 12:33 PM
just noticed that it also runs as rich as rich can get?[sm=wtf.gif]
enginekid92 Nov 9, 2008 08:53 PM
40 hits 1 reply will someone please help?
enginekid92 Nov 9, 2008 09:02 PM
sorry if i'm inpashont i take after my dad this engine is just driving me up the wall!!! [sm=imsmilin.gif]
enginekid92 Nov 9, 2008 09:04 PM
o yaeh i just checked that idel jet and it looks clear i can get high res pics if you want
Dewald Nov 13, 2008 04:53 AM
Ok.
Post the video and pics so we can see whats that problem. Make sure the video has sound.
Hury up becouse Beetles is no use standing still.
TurboBuga4 Nov 29, 2008 07:37 AM
the other thing you could try would be to just replace the carb, but at the same time, check the valve clearence on the intake side of the head, as well as valve back-lash on the exhaust side,...if you don't have good sealing valves, you will loose so much power, and your engine will stall due to the low compression that the engine has.
