-   -   Engine Oil around spark plugs... (https://volkswagenforum.com/forum/volkswagen-beetle-20/engine-oil-around-spark-plugs-35428/)
rrgrassi Nov 12, 2012 02:38 PM
While changing the sparkplugs on the 1.8, I noticed engine oil around the sparkplugs. I could not see any cover gasket leaks though.
Where could the oil com from?
Keithuk Nov 12, 2012 06:17 PM
Now thats a strange thing the oil on spark plugs thread. If the cam cover/rocker cover gasket isn't leaking I've now idea where it comes from.
motorking Nov 14, 2012 05:17 AM
oil around plugs
Good morning,
I am the technical manager at Autolite spark plugs. the 1.8 has seals under the valve cover that seal around the spark plug wells. they get brittle and leak oil into the plug wells. The seals come with a good quality valve cover gasket. Oil on the plug boots will cause misfires too.
Good luck fixing, let me know if you need repair instructions.
jay.buckley@framgrp.com:D
Ambrosemartin Jan 31, 2013 11:59 PM
Thanks for providing a batter suggestion to know about the spark plugs problem. I prefer to regular time checked my cylinder heads and also do auto services. I thinks it's a nominal problem to spark plugs nearest the engine.
