Engine Oil around spark plugs...
I am the technical manager at Autolite spark plugs. the 1.8 has seals under the valve cover that seal around the spark plug wells. they get brittle and leak oil into the plug wells. The seals come with a good quality valve cover gasket. Oil on the plug boots will cause misfires too.
Good luck fixing, let me know if you need repair instructions.
jay.buckley@framgrp.com
onecrazyfuq
Aug 27, 2006 01:56 AM
