Door locked shut
Old May 16, 2006 | 11:36 AM
danlewi's Avatar
Default Door locked shut
I went to get in my 73 Super the other morning and discovered my key would not unlock the door, nor would it unlock from the inside. I've had these doors apart before and I'm trying to figure out what my next step is going to be--take the panel off and try to get to the lock from there? Any suggestions? Thanks!
Old May 16, 2006 | 02:21 PM
toledotom's Avatar
Default RE: Door locked shut
I owned a 73 bug also, The screws for the door handle I thought were either on the side jamb of the door or the front cover pops off - or was that the Rabbit? Mostly the plastic cam on the inside when you pull the handle has top be replaced or cast piece breaks for the lock mechanism.
Old May 16, 2006 | 06:03 PM
p_mister's Avatar
yha sounds like a small peice in broke off in the lock mecinism. pull it and check what you find.
tony
Old May 18, 2006 | 05:39 PM
danlewi's Avatar
Thanks for the responses! I'll keep them in mind. However, the day I posted this I went back out to finish some other work on my bug--much needed tlc after several months--and the door freed itself up! I'd like to chalk this incident up to my car trying to get my attention after feeling neglected.
Old May 18, 2006 | 06:14 PM
p_mister's Avatar
just like the movie hurbie i guess [:P]
tony
Jan 11, 2011 12:55 AM
Jan 6, 2011 03:10 PM
swiggs01
Jan 6, 2009 02:52 PM
ereprac05
Aug 16, 2008 11:28 PM
kcguy
Apr 22, 2008 04:34 PM
