-   -   Clunking sounds from driver side rear tire (https://volkswagenforum.com/forum/volkswagen-beetle-20/clunking-sounds-driver-side-rear-tire-5360/)
cory Apr 1, 2008 10:36 AM
I have a 1968 bug with a bugatti fiberglass kit on it. When driving at any speed the driverside rear tire clunks. The clunk sppeds up as the car speeds up so i thought it might be the bearing but I took a look and the bearing looks fine. Any suggestions of where to look next???
cory Apr 11, 2008 03:18 PM
RE: Clunking sounds from driver side rear tire
Wow 51 veiws and no replies. Does anyone know about cars on this forum?? Please help me out! :)
bagel Apr 12, 2008 01:06 PM
No one replied prolly cause they don't know about '68 bugs. I know less than zero about '68 bugs, but a front end noise has something to do with the suspension. You checked the wheel bearings right? Becuase these cars are rear motor/rear drive, there maybe an axle going bad or something. Other than that, I don't know I'd have to look into it and do some research.
knightrs32 Apr 12, 2008 01:17 PM
Oh, come on bagel, several of us know about the old bugs, there are just some problems that elude us! :)
Mine does the same thing, but on all four corners. I'm still searching...
bagel Apr 12, 2008 01:22 PM
I'm not taking anything away from anyone on here; would it have sounded better if I said n o one replied cause they didn't want to? Anywyas, I'll look, too.
cory Apr 12, 2008 06:28 PM
Hey don't worry about bagel I found a forum where people acually try and help out.
Thanks for the help knightrs32!
pimemtel Apr 12, 2008 06:42 PM
Cory can you pm me with the forum.
thanks
Jrailer Apr 12, 2008 10:05 PM
how did you pull the bearing without pulling the axle tube?
or did you just look at the bearing
they dont go bad that often on swing axle trans
possibly a drum starting to stripout
Sorry i have been helping other people didnt see your topic untill today
Jrailer Apr 12, 2008 10:17 PM
i have seen when people put to long of wheel studs (lug bolts)in and they hit the wheel cylinder or brake hardware
cory Apr 15, 2008 03:08 PM
Yea I think that I got it figured out after all that work it was just the wheel spacer. thanks to those with advise.
