-   -   A/C Compressor does not run (https://volkswagenforum.com/forum/volkswagen-beetle-20/c-compressor-does-not-run-12056/)
sharrer Jun 5, 2009 02:24 PM
A/C compressor does not run in 98 beetle automatic. Fuses are good but I have not tracked down the other permissives that allow the compressor to run. Are there any common failures for this year and model such as switches or relays?
:confused:
racerx002 Jun 6, 2009 06:54 PM
There are a lot of sensors, switches and a couple of relays that could be the problem. First, are your cooling fans running?
sharrer Jun 8, 2009 01:34 PM
The cooling fans cycle on and off during normal driving with the A/C compressor off but do not turn on when the compressor has been switched on. I tried this after the car was up to normal operating temperature and after I saw the fans cycle a few times.
reagd Sep 11, 2009 01:50 AM
Originally Posted by sharrer (Post 25382)
A/C compressor does not run in 98 beetle automatic. Fuses are good but I have not tracked down the other permissives that allow the ac compressor to run. Are there any common failures for this year and model such as switches or relays?
:confused:
Try checking your cooling fans. Mine got nasty wirings & some busted relays & some sensors screwed up.
lovely09 Sep 16, 2009 01:19 AM
If that so,maybe you need to fix it up first and see if the problem was still there.Wiring and sensors should be on their right places.That is,we can determine where's the problem coming from.
