A/C Compressor does not run
Old Jun 5, 2009 | 02:24 PM
sharrer's Avatar
Default A/C Compressor does not run
A/C compressor does not run in 98 beetle automatic. Fuses are good but I have not tracked down the other permissives that allow the compressor to run. Are there any common failures for this year and model such as switches or relays?
Old Jun 6, 2009 | 06:54 PM
racerx002's Avatar
There are a lot of sensors, switches and a couple of relays that could be the problem. First, are your cooling fans running?
Old Jun 8, 2009 | 01:34 PM
sharrer's Avatar
The cooling fans cycle on and off during normal driving with the A/C compressor off but do not turn on when the compressor has been switched on. I tried this after the car was up to normal operating temperature and after I saw the fans cycle a few times.
Old Sep 11, 2009 | 01:50 AM
reagd's Avatar
Originally Posted by sharrer
A/C compressor does not run in 98 beetle automatic. Fuses are good but I have not tracked down the other permissives that allow the ac compressor to run. Are there any common failures for this year and model such as switches or relays?
Try checking your cooling fans. Mine got nasty wirings & some busted relays & some sensors screwed up.
Old Sep 16, 2009 | 01:19 AM
lovely09's Avatar
If that so,maybe you need to fix it up first and see if the problem was still there.Wiring and sensors should be on their right places.That is,we can determine where's the problem coming from.
tanu
Feb 22, 2010 03:56 AM
tanu
Feb 22, 2010 03:52 AM
RONN_H
Jul 9, 2009 05:07 AM
rattlesmith
Oct 16, 2006 01:17 AM
