D/S door lock
D/S door lock
Hi guys. I had a lock cylinder that was not unlocking the front D/S door and took it out by removing the screw in the door frame that was holding it in place. I used a repair kit to fix the lock. When I used the screw I removed to reinstall the lock, the mounting bracket in the inner door cracked. I replaced bracket which holds both the door handle and the lock cylinder in place.
I now have a working lock, but no matter how tight I make the screw in the door frame that is used to hold the lock in place, the lock will stay in place for a while, but eventually will loosen after a few times of pulling on the door handle when opening the door.
When I removed the screw in the door frame is it possible I broke some other part that is needed to hold the lock in place?
Please provide any resources, and/or instructions that would help me solve this lock problem.
A diagram or photo of the different parts that hold the D/S door handle and lock cylinder in place would be helpful.
Thanks,
Bill
Thanks,
Bill
You can Goggle VW parts online, ETKA.
