Automatic Transmission fluid
My wife has just bought a 2003 2L soft top and the gear changes are a bit harsh from time to time so the ATF is in need of a change. Only there is nothing in the owners book about the ATF so wondered if anyone has ever changed it or know of any good resources on how to do it. A VW garage quoted it only needed a litre of fluid which I though was a bit low(?)
Anyhoo, any help would be much appreciated |
1 Attachment(s)
Welcome to the forum Adam. Attachment 3128
Well you say you have a 2003 Beetle 2.0 so the spec that Autodata says is: Beetle (98-11) 2,0 1998-09 Engine code: AQY Automatic transmission fluid: 01M gearbox = G 052 162 09G gearbox = G 052 025 Automatic transmission (drain & refill): 3.0 litres 01M gearbox
Cheers, does this mean its not the DSG transmission?
So it doesn't have an oil filter type ATF filter and one thats in the fluid pan? From what information I can find is that I drain the fluid by removing the sump plug and then the plastic overfill tube. Then remove the sump pan to get to the filter to replace that. Then put the pan back on with new filter and pretty much fill up with about the same amount of what came out. Start the car and top up until it drips out and then put the sump plug back in. VW are sure it's only a litre of fluid I need. |
found out its the tiptronic transmission, so would be the OG9 as its the 6 speed one.
