auto choke problem
does anyone else have a problem with the automatic choke cooling down faster than the car itself, and then not being able to start the car later because the choke is closed?[/align] |
RE: auto choke problem
Sounds like the choke is adjusted too tight , that would
make the choke close when the spring is just starting to cool off instead of waiting untill it's cold. When the engine is cold ( sitting over night cold ) loosen the screws holding the choke element and rotate it and see the choke plate back off a bit then rotate the element in the direction to make it just close and then tighten the screws. |
| All times are GMT -5. The time now is 04:48 AM. |
