2000 VW Beetle Cooling Fans
I need help. I cannot get the cooling fans on my 2000 VW Beetle 1.8GLS to come on. I have verified that all fuses are the required ratings and that they are in fact ok (tested with OHM Meter). With advise from several "mechanics", I have replaced the Fan Control Module, the sensor on the side of the radiator and the sensor by the inlet. (meaning all sensors have been replaced). The fans tested "good"(they came on}when I took them to the local electric motor guy and have worked (twice) in the car when you ground the sensor on the input (before the "T" that splits off to the electric pump). But I cant get them to run when you turn the A/C on or once the vehicle has been running. Any Ideas??
Welcome to the forum.
If you find someone with VAG-COM\VCDS there are more tests you can do.
vitbobrov
07-02-2011 08:37 PM
