2006 beetle purge valve
Old Apr 19, 2010 | 06:55 PM
glolar's Avatar
Default 2006 beetle purge valve
Hello all,
Cannot find a purge valve for my 2006 Beetle anywhere online (can only find up to year 2005). Assuming I have to go to a dealer then? Also, I have heard of something called a "factory immobiliser" that will shut down my car's computer if I try to replace the purge valve myself. Any truth to that?
Symptoms: Check engine light on. Car is hard to start (rich) ONLY after I fill up the gas tank. Once I get it started and rev the motor a couple of seconds, everything is fine until I fill up again. Is this in fact a purge valve that is stuck open? Can I remove the existing one, clean it, and possibly re-install without a problem with the afore-mentioned "immobiliser"? Thanks in advance!
billkraigsley
Jan 27, 2013 10:42 AM
huyuhy
May 9, 2011 05:03 AM
cmacs vw cabrio 388hp dyno
Jan 20, 2010 06:33 PM
blujet
Apr 27, 2006 03:32 PM
humblebumble
Mar 18, 2006 03:53 PM
