2003 New Beetle, auto transmission woes...
Hi all,
My wife's Beetle has been shifting with a whiplash-inducing jerk for the past few months, and finally got stuck in third gear last week. It was suggested that I check the transmission fluid before spending thousands of dollars on a new transmission - so, with my handy Haynes guide in tow I researched it, figured that I could do it, got everything I needed including new fluid, new plugs, new filters, etc and got to work. According to VW, the transmission case is a "sealed" system, and there's almost no way to access the fluid. You can unscrew a small bolt and check the level, and pop out another plug and fill the thing, but there's no easy way to do either. Get the fluid up to at least 95 degrees, take out the bolt, and if a few drops come out then the fluid level is correct. If it's not, you have to add a little bit at a time until the level is correct. To my knowledge (and I would know), the car has NEVER had its transmission fluid changed. Now, I'm not a beginner mechanic; I've changed the timing belt and water pump on her car already, done all the brakes and oil changes, spark plugs, etc. I've also done nearly all the work on my car (Ford Escort) for the past seven years including changing out the bushings around the main drive shaft inside the engine, replacing the exhaust system, etc. I'm not a pro, but I know my way around an engine reasonably well. The only thing I haven't been able to handle is a complete rebuild of my automatic transmission. I took out the check-level bolt, and brownish fluid started pouring from the small hole - nothing like the red of transmission fluid, it obviously needs to be changed - but here's the rub: I can't get the fill-plug out without forcing it, and I'm nervous about doing so. And, even if I get the fill-plug out, the access hole is nearly impossible to access. Lastly, I truly don't see how the Beetle can have 7.4 quarts of transmission fluid inside that one little pan. Any advice would be extremely helpful. At this point, I'm ready to call AAA and have the car towed to the dealer, never to work on the transmission again. Thanks in advance. Tai |
2003 New Beetle auto transmission woes
Now that China is ready to eclipse Germany in VW sales all is looking even better overseas for the company.
yeah,,tow it to the dealer..they have good quality oem part there to replace your cars defective parts..
I feel your pain...
I have a 2003 as well and my valve body had to be replaced last year. Now my tranny totally quit. My delima is that the car is only worth $4500 and a new tranny will cost me that much. I'm leaning more towards selling it for whatever I can get and get a new VW that's not made in Mexico. :mad:
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system accessories for replacement, such as Fuel injection Nozzle, Plunger and Delivery valve, ETC In south of china . for more detail please visit our website : www.yellowstonediesel.com www.dieselinjection.cn Yellow stone diesel parts plant was founded in 1997.Over the years, Yellow stone has grown and gained a reputation for producing high quality products and delivering them on time. 105015-5860 105015-5860 105015-5940 0 433 171 134 0 433 171 137 0 433 171 146 5611065 H60S30A538 5611650 BDL110S6133 5611735 BDL110S6267 6801082 6801082 6801087 6801087 6801088 6801088 DN10PDN130 DN0PDN121 HL176S27D525P2 2418455518 2455-518 2418455714 2455-714 9401087506 9087-506 134151-4120 P121 134151-4920 P129 134151-6420 P143 NOZZLE DENSO 093400-7690 DN10PDN129 NOZZLE DENSO 093400-7700 DN10PDN130 NOZZLE DENSO 093400-8220 DN0PDN121 131110-9320 131110-9420 131160-0320 |
| All times are GMT -5. The time now is 09:53 AM. |
