2000 beetle lots of problems where to start
Have 9 codes: where do I start!
0725 1850 0103 0137 0300 0302 0303 0304 1780 Dealer wants 120 per hour to " diagnose" and with this many codes I think it might be cheaper to buy a different car! I live in bay City MI. |
1 Attachment(s)
Welcome to the forum. Attachment 2667
Error codes are 5 characters. VAG Error Code: 00725 Fault Location: Footwell Vent Switch: Right Rear (F186) Possible Cause: Wiring/Connector(s). Footwell Vent Switch: Right Rear (F186). VAG Error Code: 01850 Fault Location: Temperature Sensor for Heated Seat: Right Rear (G95) - Open Circuit or Short Circuit to Positive Possible Cause: Wiring/Connector(s). Fuse(s). Temperature Sensor for Heated Seat: Right Rear (G95). VAG Error Code: 00103 Fault Location: Interior Locking Button: Right Rear (E311) - Electrical Fault in Circuit Possible Cause: Wiring/Connector(s). Interior Locking Button: Right Rear (E311). Possible Solutions: Check/Replace all faulty Wiring/Connector(s). Read Measuring Value Blocks (MVB). VAG Error Code: 00137 Fault Location: Left Rear Wheel Acceleration Sensor (G339) - Electrical Fault in Circuit Possible Cause: Wiring/Connector(s). Left Rear Wheel Acceleration Sensor (G339). Possible Solutions: Check/Replace all faulty Wiring/Connector(s). Read Measuring Value Blocks (MVB). VAG Error Code: 00300 Fault Location: Transmission Fluid Temperature (TFT) Sensor (G93) - Short Circuit/Malfunctioning/Implausible Signal Possible Cause: Malfunction Indicator Lamp (MIL)(K83) active. Transmission Not Shifting Properly or in Limp Mode. Wiring/Connectors from/to Transmission Fluid Temperature Sensor (G93). Transmission Fluid Temperature Sensor (G93) faulty. Possible Solutions: Check Wiring/Connectors from/to Transmission Fluid Temperature Sensor (G93). Check Voltage Supply for Transmission Fluid Temperature Sensor (G93). Read Measuring Value Blocks (MVB) for Transmission Fluid Temperature Sensor (G93) readings. Check/Replace Transmission Fluid Temperature Sensor (G93). VAG Error Code: 00302 Fault Location: Anti-Lock Brake System (ABS) Solenoid Valve Relay (J106) (inside ABS Control Module (J104) - Open Circuit or Resistance too High - Intermittent Possible Cause: Wiring/Connector(s). Open circuit or resistance too high between earth of ABS Solenoid Valve Relay (N106) (terminal 85) and ABS Control Module (J104) (terminal 87). Open circuit or resistance too high between voltage supply of ABS Solenoid Valve Relay (N106) (terminal 86) and ABS Control Module (J104) (terminal 2). Short circuit to B+ or earth in one of the activation wires. Incorrect control module. Voltage supply too low for ABS Solenoid Valve Relay (N106) (terminal 30). ABS Solenoid Valve Relay (N106) or ABS Hydraulic Unit (V55) malfunctioning. VAG Error Code: 00303 Fault Location: Board Computer Function Selector Switch (E91) Possible Cause: Unknown Symptom, Cause or Solution. VAG Error Code: 00304 Fault Location: Control Circuit Regulator for Fresh Air Blower Possible Cause: Unknown Symptom, Cause or Solution. VAG Error Code: 01780 Fault Location: Sensor for Vehicle Levelling - Mechanical Malfunction - Intermittent Possible Cause: Wiring/Connector(s). As taken from my https://volkswagenforum.com/forum/ge...oftware-34973/ |
Codes
I have checked my codes multiple times on different machines and the are always P followed by 4 numbers... What I found is as follows...
P0301 I found this to be a Cyl 1 Miss P0725- Engine Speed Malfunction P1850...Dont have rear heated seats... Online shows that this is for the TCM missing a message from the ECU P0103 - Mass Airflow P0137 - Shows to be an O2 sensor P0300 -Random Miss P0302 - Cyl 2 Miss P0303 - Cyl 3 Miss P0304 - Cyl 4 Miss P1780... Dont have self leveling suspension... I find that its a TCM malfunction... whatever that means...1780 is for park/neutral switch malfunction. These are what I found by googling the P number. I am sure the VAG com number is gonna give something different... or is it? Just trying to figure this D@mn car out!!!!!!!:confused: |
Well those are the results of the codes you've posted in my VAG software, Google them.
| All times are GMT -5. The time now is 07:41 AM. |
