2002 1.8 Turbo misfires
Old 09-13-2017, 05:55 PM
Paul Chapman's Avatar
Default 2002 1.8 Turbo misfires
Hi folks,
My son has got himself an 02 turbo bug as his first car.
Its got over 200,000 KM on the clock so has had a good life.
Its developed a misfire which the previous sellers had fixed prior to our collection. I don't know what they did and neither do they...
I got me a scanner and the below are all of the results held in memory
(I then reset all faults prior to doing a 5 km drive and re-scanning):
OBDII/EOBD Diag
PO300 Random/multiple cylinder misfire detected
PO303 cylinder 3 misfire detected
PO420 catalyst efficiency below threshold (bank 1)
17608 -035 KWP 1281
Boost Pressure control valve (N249): mechanical malfunction: P1200
Again this one came up after the reset, drive and re-scan
17559 -163
Long term fuel trim additive air bank 1: range 1: system too lean : P1151
17978 -163
Engine start blocked by immobilzer: P1570
16795 -163
Secondary air injection system: incorrect flow detected : P0411
16684 -035
Random/multiple cylinder misfire detected : P0300
Static - no
16688 -163
Cylinder 4 misfire detected : P0304
16685 -164
Cylinder 1 misfire detected : P0301
16687 - 035
Cylinder 3 misfire detected : P0303
Static - no indication on
16686 -163
Cylinder 2 misfire detected : P0302
17772 -163
Cylinder 4 ignition circuit open circuit : P1364
16804 -035
Catalyst system: bank 1: efficiency below threshold : P0420
ECU information
VAG No: 06A906032JR
Component: 1.81 5VT NB AG4 3999
Coding: 00003
WSC: 00066
Readiness test all passed
Readiness test after reset, drive and re-scan
Catalyst fail
Evap sys fail
Sec air sys fail
Airbag light is always on and the scanner always gets a link error
Can i turn off this light?
I appreciate any guidance on fixing this vehicle. I don't want to fix by part replacement until the misfire goes away!
Old 09-14-2017, 06:24 AM
Originally Posted by Paul Chapman
Hi folks,
OBDII/EOBD Diag
P0300 Random/multiple cylinder misfire detected
P0303 cylinder 3 misfire detected
P0420 catalyst efficiency below threshold (bank 1)
17608 -035 KWP 1281
17559 -163
17978 -163
16795 -163
16684 -035
Static - no
16688 -163
16685 -164
16687 - 035
16686 -163
17772 -163
16804 -035
ECU information
VAG No: 06A906032JR
Coding: 00003
WSC: 00066
Catalyst fail
Evap sys fail
Sec air sys fail
Bold codes.
VAG Error Code: 17608/004608
EOBD II Error Code: P1200
Fault Location:
Boost Pressure Control Valve (N249) (Turbocharger Recirculating Valve) - Mechanical Malfunction
Possible Cause:
Power Loss.
Boost Pressure Control Valve (N249) (Turbocharger Recirculating Valve) faulty.
Diverter Valve faulty.
Possible Solutions:
Check/Replace Boost Pressure Control Valve (N249) (Turbocharger Recirculating Valve).
Check/Replace Diverter Valve.
VAG Error Code: 16687/10593/6352/000771
EOBD II Error Code: P030
Fault Location:
Cylinder 3 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Wiring/Connector(s).
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Engine Control Module (ECM) damaged.
Possible Solutions:
Do a compression test.
Read Measuring Value Blocks (MVB) 15 if misfire changes location.
Special Notes:
Tech Notes:
The P0303 code means that the cylinder 3 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 3. If the problem persist more tests needs to be done to diagnose problem.
Description:
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Engine Speed (RPM) Sensor (G28)/Crankshaft Position Sensor (G28) signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
As taken from my new As taken from my new EOBD II Fault Codes Software
Old 09-14-2017, 07:36 AM
Many thanks for the reply. Gives me some direction.
i will get onto it and come back if it doesn't go to plan.
Thanks
Paul
GreatPlain
09-06-2018 12:34 PM
Vandal
09-18-2010 12:40 AM
ahansen
02-24-2008 06:44 AM
bobbybentley
08-23-2006 07:26 PM
ezgoin2578
06-07-2006 06:02 PM
Quick Reply: 2002 1.8 Turbo misfires
