07' Oil filter change?
First off what engine and do you have a new oil filter already?
If you have the new one, take it out of the box and look for the piece that looks the same but maybe different colors.
If you have the 2.0 non turbo engine, you need to remove the skid plate under the car to get to the oil filter. To remove the skid plate you will need a torx bit. Hopefully this helps. Remember only hand tight when you install the oil filter!
LMAO!! Smokin' Dog!! WalMart Service Center? What kind of forum we running here!!! LMAO Yea it's under the skid plate, and you use an 1 1/8in or 1/16 box wrench,I think. I dunno I use pliers now cause mine is getting stripped.
Literally the only room I have is behind the engine against the firewall. I figured that's where I'd put the turbo, but nope I've seen peopl with it right next to the motor. Crazy how there's completely no room anywhere in the engine compartment.
