-   -   02 Beetle leaking (https://volkswagenforum.com/forum/volkswagen-beetle-20/02-beetle-leaking-1901/)
dj10dj777 Nov 22, 2006 06:04 PM
02 Beetle leaking
I have a 2002 beetle with sunroof tdi.
the floorboard is soaked when it rains hard, just recently started this.
The leaking is coming from the top corner of the window (it seems)
Are there drain vents for the sunroof ? could they be clogged ?
THX
Don
02 BlueBeetle Nov 28, 2006 12:56 AM
RE: 02 Beetle leaking
My 2002 Beetle leaks water in as well. I have found that mine comes in from the right and left back windows. It kind of drips from the top of the window. It only leaks when it rains really hard or go through a high pressure car wash. Recently had a VW roof rack on the car, took it off yesterday to see if that was what was causing the leak. It's not rained yet, so we are just waiting to see what happens. I do recommend a couple tubs of Damp Rid. It has helped the dampness tremendously in mine. You can pick it up at your local Lowes in the cleaning supplies dept.
Good Luck!
